Wifi pro speed fluctuates daily
timcoombs
I have been reading many similar posts but have been unable to find a permanent solution to my problem.
I have two wifi pro routers in my house, one hardwired to my fibre modem and the other as a booster. The network speeds I get throughout my house on my iPhone, iPad, android and windows laptop fluctuate wildly every day. Some days the speed is 300-400mbps and some days it is down to 5-8mbps. Luckily the speed is consistent across all devices…either all are really fast or really slow.
When the speed is slow, I just need to do a network reset and the speeds increase. But that is really annoying to have to do everyday. I read one post where a guy programmed a power bar to cycle power on and off throughout the day to keep network speeds up. That seems excessive. Any idea why the network speed varies from day to day and why a daily reset is needed to fix it?
For reference, I always check the modem speed as well to make sure the issue is not with the fibre. The speed at the modem is 600mbps every single time! Why can’t this Google wifi pro be that reliable?
2 REPLIES 2
georgehenry667
Here are some reasons for fluctuating speeds and potential solutions:
  1. Interference: Other devices like microwaves may interfere. Try changing WiFi channels or using the 5GHz band.
  2. Overcrowded Channels: Switch to a less congested channel for better performance.
  3. Firmware Issues: Ensure your routers and modem are updated with the latest firmware.
  4. Router Placement: Move routers to central locations to improve signal strength.
  5. ISP Throttling: Contact your ISP to check for any network congestion or throttling.
  6. Background Traffic: Check for devices consuming excessive bandwidth.
If resetting works temporarily, consider automating it with a smart plug. For more help, visit sincere mechanic for networking tips.
GabrielaG
Hi ,
Thanks for reaching out to the community. I am sorry that your Wifi pro speed fluctuates daily, but no need to worry; help is here.
To provide you with accurate troubleshooting steps, I would appreciate your assistance in answering the following questions:
  • What kind of Google WiFi device do you have?
  • How many WiFi devices do you have?
  • When did the issue first occur?
  • What is the phone device?
  • What is the light color of the main router?
  • What troubleshooting steps have you done?
  • Who is your Internet service provider?
  • Have you already talked with your Internet service provider?
  • Recently there was a power outage in your area.
Keep me posted so I can provide you with further assistance.
Gabriela
