08-18-2025 10:02 PM
I am integrating Google Smart Home with my IoT devices (Node.js + Firebase Functions + MQTT).
When the user says “Turn on fan”, the onExecute handler is triggered, but the fan operation happens with a noticeable delay (2–3 seconds).
Here’s the relevant flow in my code:
The updateDevice function publishes MQTT commands (encrypted with key/iv) to the device’s topic.
After that, I also call reportState to update Google HomeGraph.
Devices eventually respond, but the Google Assistant action feels slow compared to Alexa integration with the same backend.
What I’ve tried / noticed:
If I publish directly to MQTT (bypassing Google onExecute), the fan reacts instantly.
Delay seems to come from my cloud function or how I handle subscriptions inside updateDevice.
I already added a withLock per device to avoid parallel execution clashes.
I suspect client.on('message') listeners or subscribe/unsubscribe inside updateDevice may be introducing delay.
Question:
How can I reduce the delay in the Google Smart Home onExecute → MQTT execution path?
Should I avoid dynamic subscribe/unsubscribe inside updateDevice and instead maintain a persistent subscription?
Is there a better pattern for publishing MQTT commands in response to Google Smart Home intents (so the device action is instant)?
08-21-2025 10:51 AM
The delay comes from creating subscriptions or cold starts inside onExecute. To fix this, maintain a persistent MQTT client (don’t dynamically subscribe/unsubscribe on every request), publish directly during execution, and call reportState after the action. If you’re on Firebase Functions, set minInstances to reduce cold-start lag.
To your specific questions:
Should I avoid dynamic subscribe/unsubscribe? → Yes, use a persistent connection instead.
Is there a better pattern for publishing MQTT commands? → Yes, keep the MQTT client alive, publish immediately on onExecute, and then update Home Graph with reportState. This ensures the device action feels instant.
08-21-2025 10:51 AM
