2 weeks ago - last edited 2 weeks ago
I was successful at Automating my SmartSwitch to turn on when the AC Kicks on and off (Attached). I wish to automate for the "Fan- Only" setting on my NEST thermostat.
Im getting an error [fan-only] is an invalid enum string. The list of valid enums: [on, off, heat, cool, heatcool]. When i check the Nest Developer page it states that "Fan-Only" should be a command. Any help would be appreciated.
https://developers.home.google.com/cloud-to-cloud/traits/temperaturesetting
metadata:
name: Lights ON when Fan-Only runs
description: If the thermostat is actively in fan-only mode, turn ON SmartSwitch
automations:
- starters:
- type: device.state.TemperatureSetting
device: Hallway - Hallway
state: activeThermostatMode
is: fan-only
actions:
- type: device.command.OnOff
devices:
- SmartSwitch
on: true
To turn on smart switch when AC kicks on:
metadata:
name: Scent diffuser ON when AC is cooling
description: If the thermostat is actively cooling, turn ON SmartSwitch
automations:
- starters:
is: cool
actions:
- type: device.command.OnOff # Turn the device on or off.
devices:
- SmartSwitch
on: true
To Turn off With AC off:
metadata:
name: Scent OFF when AC stops
description: When cooling ends (idle), turn OFF SmartSwitch.
automations:
- starters:
isNot: cool
actions:
devices:
- SmartSwitch
on: false
2 weeks ago
The issue is that "fan-only" isn't a valid value for the activeThermostatMode
state in Google Home automations.
According to the documentation you linked, the valid values for activeThermostatMode
are:
"Fan-only" is a thermostat mode that exists on the device itself, but it's not exposed as a triggerable state in the Google Home automation system.
Workaround options:
Unfortunately, this is a limitation of the current Google Home automation system - not all thermostat modes are available as automation triggers. Your automation syntax is correct; the platform just doesn't support that particular mode value.
2 weeks ago
are:
Workaround options:
Tuesday - last edited Tuesday
