06-01-2025 12:48 PM
I'm having trouble retrieving the correct power state of my MELCloud air conditioner when using home automation scripts via Works with Google Home.
- The MELCloud account is linked to Google Home.
- I can control the air conditioner using voice commands and via the Google Home app device controls.
- When I ask the voice assistant for the current power state, it responds with correct power state.
- The Google Home app device also displays the correct power state.
The problem rises with the automation script editor. It always reports the AC as on, even when it's off. The incorrect power state prevents me from using the power status as a condition in my automations.
Has anyone experienced this issue? Any known workarounds? I’d like to use the AC’s power state in my scripts.
06-02-2025 10:39 AM
Thanks for sharing these details. Based on your description, this seems like a potential issue related to how Google Home Automation Script Editor queries real-time device states from MELCloud.
This may suggest that:
You can try:
06-02-2025 10:39 AM
You can try:
