03-05-2024 10:10 PM
Hello Dear,
I created Matter app reference by Matter Sample app using Matter SDK and I created matter virtual device with on/off clusters and it's working well but when I try with the physical device getting issues which is mentioned below -
I tested with 2.4GHz network but still not getting success
Searching for device....
Logcat
W Frame time is 0.089496 ms in the future! Check that graphics HAL is generating vsync timestamps using the correct timebase.
addDeviceButton.setOnClickListener
CommissionDevice: starting
commissionDeviceStatus.observe: status []
ShareDevice: Success getting the IntentSender: result [IntentSender]
commissionDeviceIntentSender.observe is called with [creatorPackage [com.google.android.gms]]
CommissionDevice: Launch GPS activity to commission device
Recording user engagement, ms: 13103
commissionDeviceIntentSender.observe is called with [null]
Connecting to remote service
Connection attempt already in progress
Activity paused, time: 3750429
onCreate()
intent [Intent commissioning.AppCommissioningService ]
Connected to remote service
Processing queued up service tasks: 2
Local module descriptor class for com.google.android.gms.googlecertificates not found.
Considering local module com.google.android.gms.googlecertificates:0 and remote module com.google.android.gms.googlecertificates:7
Selected remote version of com.google.android.gms.googlecertificates, version >= 7
Dynamite loader version >= 2, using loadModule2NoCrashUtils
Application going to the background
Application backgrounded at: timestamp_millis: 1709277938430
Inactivity, disconnecting from the service
Can't find device
and Some instructions
and also I shared some code snippet when I click on add device
_commissionDeviceStatus.postValue(TaskStatus.InProgress)
val commissionDeviceRequest =
CommissioningRequest.builder()
.setCommissioningService(ComponentName(context, AppCommissioningService::class.java))
.build()
// The call to commissionDevice() creates the IntentSender that will eventually be launched
// in the fragment to trigger the commissioning activity in GPS.
Matter.getCommissioningClient(context)
.commissionDevice(commissionDeviceRequest)
.addOnSuccessListener { result ->
Log.d("", "ShareDevice: Success getting the IntentSender: result [${result}]")
// Communication with fragment is via livedata
_commissionDeviceIntentSender.postValue(result)
.addOnFailureListener { error ->
Log.d("Error", error.toString())
Log.d("Numbersss", "18")
//Timber.e(error)
TaskStatus.Failed("Setting up the IntentSender failed", error))
and this is service class
@AndroidEntryPoint
class AppCommissioningService : Service(), CommissioningService.Callback {
@Inject internal lateinit var devicesRepository: DevicesRepository
@Inject internal lateinit var devicesStateRepository: DevicesStateRepository
@Inject internal lateinit var chipClient: ChipClient
private val serviceJob = Job()
private val serviceScope = CoroutineScope(Dispatchers.Main + serviceJob)
private lateinit var commissioningServiceDelegate: CommissioningService
override fun onCreate() {
super.onCreate()
// May be invoked without MainActivity being called to initialize APP_NAME.
// So do it here as well.
Log.d("Numbersss", "3")
APP_NAME = getString(R.string.app_name)
Log.d("", "onCreate()")
commissioningServiceDelegate = CommissioningService.Builder(this).setCallback(this).build()
override fun onBind(intent: Intent?): IBinder? {
Log.d("Numbersss", "4")
Log.d("onBind():", " intent [${intent}]")
return commissioningServiceDelegate.asBinder()
override fun onStartCommand(intent: Intent?, flags: Int, startId: Int): Int {
Log.d("Numbersss", "5")
Log.d("", "onStartCommand(): intent [${intent}] flags [${flags}] startId [${startId}]")
return super.onStartCommand(intent, flags, startId)
override fun onDestroy() {
super.onDestroy()
Log.d("Numbersss", "6")
Log.d("", "onDestroy()")
serviceJob.cancel()
override fun onCommissioningRequested(metadata: CommissioningRequestMetadata) {
Log.d("Numbersss", "7")
Log.d("Requestedddddddd---->",
"*** onCommissioningRequested ***:\n" +
"\tdeviceDescriptor: " +
"deviceType [${metadata.deviceDescriptor.deviceType}] " +
"vendorId [${metadata.deviceDescriptor.vendorId}] " +
"productId [${metadata.deviceDescriptor.productId}]\n" +
"\tnetworkLocation: " +
"IP address toString() [${metadata.networkLocation.ipAddress}] " +
"IP address hostAddress [${metadata.networkLocation.ipAddress.hostAddress}] " +
"port [${metadata.networkLocation.port}]\n" +
"\tpassCode [${metadata.passcode}]")
// CODELAB: onCommissioningRequested()
serviceScope.launch {
val deviceId = devicesRepository.incrementAndReturnLastDeviceId()
Log.d("",
"Commissioning: App fabric -> ChipClient.establishPaseConnection(): deviceId [${deviceId}]")
chipClient.awaitEstablishPaseConnection(
deviceId,
metadata.networkLocation.ipAddress.hostAddress!!,
metadata.networkLocation.port,
metadata.deviceDescriptor.vendorId,
metadata.deviceDescriptor.productId,
metadata.deviceDescriptor.deviceType,
metadata.passcode)
Log.d("", "Commissioning: App fabric -> ChipClient.commissionDevice(): deviceId [${deviceId}]")
chipClient.awaitCommissionDevice(deviceId, null)
Log.d("", "Commissioning: Calling commissioningServiceDelegate.sendCommissioningComplete()")
CommissioningCompleteMetadata.builder().setToken(deviceId.toString()).build())
Log.d("",
"Commissioning: OnSuccess for commissioningServiceDelegate.sendCommissioningComplete()")
.addOnFailureListener { ex ->
Log.e("", "Commissioning: Failed to send commissioning complete.", ex)
// CODELAB SECTION END
03-07-2024 10:32 AM
Hello @Shivam29 ,
You can try working with the following commands more information about this can be found here.
adb shell setprop log.tag.gms_svc_id:336 VERBOSE
adb shell setprop log.tag.gms_svc_id:305 VERBOSE
adb shell setprop log.tag.gms_svc_id:168 VERBOSE
adb logcat | grep MatterCommissioner
Also, try to browse BLE or DNS-SD with another tool if it seems the device can't connect .
03-08-2024 06:20 AM
I think getting some timeout. I sharing some logs -
Log 1:
WifiHAL : createRequest: APF set program request
WifiHAL : Success to allocate program of len: 506
RpcRunner: (REDACTED) Retrieving ClientContext and token for %s.
MatterCommissioner: No matching devices discovered. [CONTEXT service_id=336 ]
SetupDeviceViewModel: Commissioning failed with state Failed to discover commissionable device. [CONTEXT service_id=336 ]
SetupDeviceViewModel: m.vxc: Timed out waiting for 60000 ms
SetupDeviceViewModel: at m.vxd.run(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):56)
SetupDeviceViewModel: at android.os.Handler.handleCallback(Handler.java:958)
SetupDeviceViewModel: at android.os.Handler.dispatchMessage(Handler.java:99)
SetupDeviceViewModel: at android.os.Looper.loopOnce(Looper.java:205)
SetupDeviceViewModel: at android.os.Looper.loop(Looper.java:294)
SetupDeviceViewModel: at android.app.ActivityThread.main(ActivityThread.java:8248)
SetupDeviceViewModel: at java.lang.reflect.Method.invoke(Native Method)
SetupDeviceViewModel: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:552)
SetupDeviceViewModel: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:971)
SetupDeviceChimeraActiv: Showing error status. [CONTEXT service_id=336 ]
SetupDeviceChimeraActiv: m.guw: Timed out waiting for 60000 ms
SetupDeviceChimeraActiv: at m.hde.b(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):459)
SetupDeviceChimeraActiv: at m.hde.a(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):3)
SetupDeviceChimeraActiv: at m.wae.a(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):60)
SetupDeviceChimeraActiv: at m.wbo.a(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):84)
SetupDeviceChimeraActiv: at m.wea.a(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):3)
SetupDeviceChimeraActiv: at m.wdz.a(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):137)
SetupDeviceChimeraActiv: at m.etm.b(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):109)
SetupDeviceChimeraActiv: at m.eta.invokeSuspend(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):11)
SetupDeviceChimeraActiv: at m.vmn.resumeWith(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):14)
SetupDeviceChimeraActiv: at m.vuy.a(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):53)
SetupDeviceChimeraActiv: at m.vth.E(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):89)
SetupDeviceChimeraActiv: at m.vth.G(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):28)
SetupDeviceChimeraActiv: at m.vth.A(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):2)
SetupDeviceChimeraActiv: at m.vth.resumeWith(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):24)
SetupDeviceChimeraActiv: at m.vwv.b(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):5)
SetupDeviceChimeraActiv: at m.vwl.j(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):89)
SetupDeviceChimeraActiv: at m.vwl.y(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):295)
SetupDeviceChimeraActiv: at m.vwl.C(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):201)
SetupDeviceChimeraActiv: at m.vwl.B(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):6)
SetupDeviceChimeraActiv: at m.vst.resumeWith(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):5)
SetupDeviceChimeraActiv: at m.vmn.resumeWith(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):38)
SetupDeviceChimeraActiv: at m.vux.run(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):106)
SetupDeviceChimeraActiv: at android.os.Handler.handleCallback(Handler.java:958)
SetupDeviceChimeraActiv: at android.os.Handler.dispatchMessage(Handler.java:99)
SetupDeviceChimeraActiv: at android.os.Looper.loopOnce(Looper.java:205)
SetupDeviceChimeraActiv: at android.os.Looper.loop(Looper.java:294)
SetupDeviceChimeraActiv: at android.app.ActivityThread.main(ActivityThread.java:8248)
SetupDeviceChimeraActiv: at java.lang.reflect.Method.invoke(Native Method)
SetupDeviceChimeraActiv: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:552)
SetupDeviceChimeraActiv: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:971)
SetupDeviceChimeraActiv: Caused by: m.vxc: Timed out waiting for 60000 ms
SetupDeviceChimeraActiv: at m.vxd.run(:com.google.android.gms.optional_home@240854042@24.08.54 (100400-0):56)
SetupDeviceChimeraActiv: ... 8 more
WindowOnBackDispatcher: OnBackInvokedCallback is not enabled for the application.
WindowOnBackDispatcher: Set 'android:enableOnBackInvokedCallback="true"' in the application manifest.
OomAdjuster: Not killing cached processes
WifiHAL : Done!
WifiHAL : Setting DTIM config , halHandle = 0xb400007d4d147850 Multiplier = 2
WifiHAL : Successfully configured dtim multiplier 2
BoundBrokerSvc: onBind: Intent { act=com.google.android.gms.feedback.internal.IFeedbackService dat=chimera-action:/... cmp=com.google.android.gms/.chimera.GmsBoundBrokerService }
BoundBrokerSvc: Loading bound service for intent: Intent { act=com.google.android.gms.feedback.internal.IFeedbackService dat=chimera-action:/... cmp=com.google.android.gms/.chimera.GmsBoundBrokerService }
RpcRunner: (REDACTED) Executing RPC %s
pixel-thermal: neutral_therm:33.976 raw data: neutral_therm:33976
pixel-thermal: cellular-emergency:34.9063 raw data: VIRTUAL-NEUTRAL:34906.3 VIRTUAL-NEUTRAL-SKIN2:34723.9 VIRTUAL-QUIET-NEUTRAL:33836 cellular-emergency:34906.3 disp_therm:33486 gnss_tcxo_therm:35111 neutral_therm:33976 quiet_therm:33776 skin_therm1:35868 skin_therm2:36469
pixel-thermal: VIRTUAL-SKIN-CPU:34.9063 raw data: VIRTUAL-NEUTRAL:34906.3 VIRTUAL-NEUTRAL-SKIN2:34723.9 VIRTUAL-QUIET-NEUTRAL:33836 VIRTUAL-SKIN-CPU:34906.3
pixel-thermal: VIRTUAL-SKIN:34.9063 raw data: VIRTUAL-NEUTRAL:34906.3 VIRTUAL-NEUTRAL-SKIN2:34723.9 VIRTUAL-QUIET-NEUTRAL:33836 VIRTUAL-SKIN:34906.3
pixel-thermal: VIRTUAL-SKIN-CHARGE:34.9063 raw data: VIRTUAL-NEUTRAL:34906.3 VIRTUAL-NEUTRAL-SKIN2:34723.9 VIRTUAL-QUIET-NEUTRAL:33836 VIRTUAL-SKIN-CHARGE:34906.3
pixel-thermal: VIRTUAL-SKIN-CPU-GPU:34.9063 raw data: VIRTUAL-NEUTRAL:34906.3 VIRTUAL-NEUTRAL-SKIN2:34723.9 VIRTUAL-QUIET-NEUTRAL:33836 VIRTUAL-SKIN-CPU-GPU:34906.3
pixel-thermal: VIRTUAL-SKIN-HINT:34.9063 raw data: VIRTUAL-NEUTRAL:34906.3 VIRTUAL-NEUTRAL-SKIN2:34723.9 VIRTUAL-QUIET-NEUTRAL:33836 VIRTUAL-SKIN-HINT:34906.3
WifiHAL : Creating message to get link statistics; iface = 47
WifiHAL : In GetLinkStatsCommand::handleResponse
ConnectivityService: NetReassign [no changes] [c 2] [a 1] [i 14]
RpcRunner: (REDACTED) RPC %s completed successfully.
NearbyMediums: Found Fast Ble Advertisements :
NearbyMediums: BleAdvertisement { version=2, socketVersion=2, serviceIdHash=null, data=[ 0x23 0x39 0x4a 0x58 0x45 0x11 0x32 0x85 0xa3 0x20 0xd5 0x80 0x50 0x02 0x89 0xc9 0x8c 0x1b 0xbc 0x79 0x19 0xfc 0x0e ], deviceToken=[ 0x05 0xe3 ] } : 2 times.
NearbyMediums: Total 2 fast advertisements.
Log 2 :
MatterCommissioner: (REDACTED) Starting commissioning flow for sessionId: and device identifier: .
MatterCommissioner: Retrieved commissioner credentials. [CONTEXT service_id=336 ]
MatterCommissioner: (REDACTED) Looking for device with discriminator %s
MatterCommissioner: Discovery found no devices during scan. [CONTEXT service_id=336 ]
MatterCommissioner: (REDACTED) Starting commissioning flow for sessionId: %s and device identifier: %s.
Log 3 :
commissionDeviceStatus.observe: status [InProgress]
Recording user engagement, ms: 132015
Activity paused, time: 89678756
onCreate()
Application backgrounded at: timestamp_millis: 1709894450761
and also I have
Tapo Matter L535 with the
Form Factor: A19, E26
Brightness: 1100L
Color Temperature Range: 2500-6500K
03-07-2024 10:32 AM
Hello @Shivam29 ,
03-08-2024 06:20 AM
Log 1:
WifiHAL : Done!
Log 2 :
Log 3 :
onCreate()
and also I have
Brightness: 1100L
