Notify when thermostat loose power or get disconnected
alkandery75
I'm trying to create an automation to notify when thermostat loose power or get disconnected or not available:
metadata:
  name: Roof Thermostat
  description: When Thermostat Roof is not available, get a notification
automations:
  - starters:
      - type: device.state.OperationalState
        device: Thermostat Roof - Roof
        state: isOperational
        is: false
    actions:
      - type: home.command.Notification
        title: Notification
        body: Thermostat Roof is not available
Unfortunately, I'm getting error:
[device.state.OperationalState] is an unknown type name. Expected types: [time.schedule, device.state, device.event, device.state.AppSelector, device.state.ArmDisarm, device.state.Brightness, device.state.Channel, device.state.ColorSetting, device.state.Cook, device.state.Dock, device.state.EnergyStorage, device.state.FanSpeed, device.state.Fill, device.state.HumiditySetting, device.state.InputSelector, device.state.LightEffects, device.state.LockUnlock, device.state.MediaState, device.state.MotionDetection, device.state.OccupancySensing, device.state.Online, device.state.OnOff, device.state.OpenClose, device.state.Record, device.state.Rotation, device.state.RunCycle, device.state.SensorState, device.state.StartStop, device.state.TemperatureControl, device.state.TemperatureSetting, device.state.Timer, device.state.Volume, device.event.DoorbellPress, device.event.MotionDetection, device.event.PersonDetection, device.event.PackageDelivered, device.event.AnimalOtherDetection, device.event.FaceFamiliarDetection, device.event.FaceUnfamiliarDetection, device.event.MovingVehicleDetection, device.event.Sound, device.event.PersonTalking, assistant.event.OkGoogle, home.state.HomePresence, etc].
Please advise and help
arm_dpe
Solutions Expert
Solutions Expert
Thanks for sharing.
Based on the error message, the issue is that device.state.OperationalState is not a valid device state type for automations. The test is explicitly telling you what types it does recognize, such as device.state.Online.
To fix this, you should change the trigger type in your automation to use a supported state that indicates the device's availability.
Try below script and let me know if it worked for you:
metadata:
automations:
starters:
type: device.state.Online
state: isOnline
is: false
actions:
title: Notification
arm_dpe
Solutions Expert
Solutions Expert
Thanks for sharing.
metadata:
automations:
starters:
state: isOnline
is: false
actions:
title: Notification
alkandery75
Thanks for your help and support dear
It's accepted and correct now
Just one edit:
Instead of: state:
isOnline
Changed to: state:
Online
Since it gave me error with the first one
Your time and efforts are highly appreciated
Wish you a nice day
JamieTiana
  • Check circuits
