11-02-2023 08:07 AM
my setup:
i have the roborock s7 pro ultra and i bought the mop heater modul for the Roborock s8. It fits but it does not start automtically when Roborock did the work.
Now I bought a Fingerbot and build a routine for it:
starters:
- type: device.state.Dock
state: isDocked
is: true
device: Roborock S7 Pro Ultra - EG Küche
actions:
- type: device.command.OnOff
on: true
devices: Robo Trockner - EG Küche
- type: time.delay
for: 1hour58min
- type: device.command.OnOff # Turn the device on or off.
on: false
- type: time.delay
for: 1min
on: true
- type: time.delay
for: 1hour58min
on: false
What does not work is that the routine starts automatically after cleaning process. I thought its triggered because device state changes to is.docked. But this does not work. Any suggestions how i can start the above routine when the robot finishes cleaning and returns to dock?
Thanks
11-16-2023 11:22 AM
Hello @madCase ,
Thanks for reaching out to us with your issue. Can your confirm the following things :
You can also make use of the Home Graph Viewer, but you will need the agent user id for roborock.
11-16-2023 11:22 AM
Hello @madCase ,
11-17-2023 07:07 AM
Thank you for your reply ! Can confirm, that is Docked shows up in the app. but with delay. Will have a look if that is the problem. Changing isdocked status faster is not possibly?
11-28-2023 02:24 AM
Checked it now for 2 weeks and automation not working! Now i always have to trigger it manually... This happens with many automations. Very unstable the google automations. Sometimes working, sometimes not!
