Smart Home Action - re-certificate
Xiaming
Hello~
I use the new console - Google Home Developer Center. When I went for testing and certification, the settings prompted me that the selected device type did not exist, but when I configured the items on the console, I selected all types.
So is there a problem with this process. I am unable to select my device, so I am unable to conduct testing and certification, which is very troublesome.
2 REPLIES 2
Derickf
Hi @Xiaming,
Thank you for reaching out to the community. I’m sorry to hear that you are experiencing issues with the Google Home Developer Center and having a prompt saying Device Type does not exist. Don't worry; help is here.
I would like to share with you the following article: Write scripted automations with the script editor. Here you will find tips about how to set a device using the script.
I hope that helps.
Derick.
GoogleDevForum
Solutions Expert
Solutions Expert
Thanks for reaching out. Can you provide us more details about your device type? The screenshot with error message will be helpful.
