04-25-2025 04:35 AM
I want to use the Condition: of my Google TV On/Off state in Google Home Scripts.
So I have this code:
automations:
starters:
- type: device.state.OnOff
device: Panasonic TV - Lounge
state: on
is: false
condition:
state: on
is: false
When it is run, I find in the log:
Automation check: conditions not met.
Starter check: conditions met.
So why is this, i.e. the check is OK to allow the script to run, but the same condition is not met in the script?
04-30-2025 07:55 AM
Thanks for clarification. You can skip/remove the condition part since turning off TV in the starter block would trigger light(s) to go off.
Can you please try the below script and let me if that worked for you:
metadata:
description: Light goes off if TV is off
automations:
starters:
state: on
is: false
device: TV - Family Room
actions:
- type: device.command.OnOff
on: false
devices: Light - Family Room
04-29-2025 11:11 AM
Can you give us more details about this home script? What you are trying to achieve with it?
04-30-2025 05:11 AM
I want to use the
condition:
state: on
is: false
in other scripts, e.g. turn off lights if (condition) TV is off
04-30-2025 07:55 AM
metadata:
automations:
starters:
state: on
is: false
actions:
on: false
04-30-2025 08:26 AM
I will test your suggestion soon.
But I already have two Starters, -type: device.state.OnOff, and -type: time.schedule(s).
I wish to retain those, hence a Condition seemed the obvious solution.
05-03-2025 06:57 AM
Your suggested script did not work. I conclude the the device.state.OnOff for this Panasonic TV is not available as a starter or condition. However, the device.command.OnOff is available.
