Using a smart switch as a starter for a routine
NickJRees
Afternoon all,
I have a little project I'm working on to automate a device at certain times, I'm using a Merros smart switch for this and the automation is working as expected via Google Home.
However, I would like to receive a notification whenever the device is operated/commanded on.
I have gone to "Household" selected the starter "when a device does something" and the smart switch is not an available option.
I have checked it's assigned to the correct household and is functioning correctly.
I just assume that this type of device (switch) is not planned for what I'm attempting to use it for ?
Are there any workarounds to enable a push notification or similar ?
thanks
Nick
sipriyadarshi
Solutions Expert
Solutions Expert
Hello @NickJRees ,
Thanks for reaching out with your issue. You can try making use of the Google Script Editor to create advanced household routines using the additional starters, conditions, actions, and advanced logic. Also, a lot of features are still under development and will be updated soon.
sipriyadarshi
Solutions Expert
Solutions Expert
Hello @NickJRees ,
NickJRees
Thanks @sipriyadarshi
I will look into the script option and see if it can help me 👍
robanoor
We appreciate you contacting us with this concern. With the new beginnings, conditions, actions, and complex logic, you can try utilising the Google Script Editor to develop sophisticated domestic routines. Many features are also still being developed and will shortly receive updates.
Larasophia
Atividades pessoal
