10-26-2022 05:44 AM
I have a stereo pair of 2 Google Home max. I can Stream Audio to the pair an it works fine.
but when i Connect my Chromecast with Google TV via Bluetooth the Sound Quallty is often very bad. Sometimes it helps to restart, but the issue is almost there every time i reconnect.
There is no issue when i connect my Bluetooth Headphones.
Also it works better when the speakers are not paired as stereo pair.
I cant find a solution for this Problem.
Why is there no Option to cast the audio from the Chromecast to another google device?
10-30-2022 09:46 AM
Hi Ohcrepes,
Thanks for posting. I totally understand that this is a good feature to use your Home Max with your Chromcast as an audio output but, this feature is not yet available. I'd suggest you submit feedback about it, here's how.
Let us know if you have other questions and concerns otherwise, we will be locking this thread after 24 hours.
Juni
10-31-2022 04:15 AM
Well that does not help at all, since i can Connect via Bluetooth but the Connection is very bad. Escpecially when the speakers are paired.
No solution for this issue?
10-31-2022 05:40 PM
Hi Ohcrepes,
Thanks for responding.
We totally understand how your setup works, however, Google Nest speakers are designed to connect and work flawlessly when playing only audio contents. We'll surely take this as a feature request and we will appreciate if you can send feedback regarding this.
Princess
