Customize Max Home Screen?
Hiyaki
I bought the hub max thinking from the advertisements that this device would be good to help organize my ADHD. I have no interest in "reliving memories" or seeing the weather for the 3rd time on a different card/widget. I want to be able to see my to-do list/calendar easily.
I have found other forums of people asking the same questions, but there has been no definitive answer. Did I pay $230 for a picture frame, loud Google assistant?
cifuentesj
Hi @Hiyaki,
Thank you for your post and the detailed information you've provided. I understand that you want to customize your Google Nest Hub Max's screen with your calendar or to-do list. At this moment this feature is not available, and you can use the Photo Frame to customize your Google Nest Hub Max's screen. Please consider sharing your thoughts directly with our development team through this feedback. Your input will help us prioritize features and ensure that we're meeting the needs of our diverse user base.
Warm regards,
Jeremy.
