12-31-2022 07:46 AM
Hi! When I have adjusted the Treble and Bass on my Nest Audio speaker it sounds fine. But if I paus or change track on my Spotify it changes back the treble and bass. When I then go in to the menu again the settings looks okay but I have to drag one of the controls (for example the treble) back and forward and the sound changes back to the settings that already are set. Any tips to make the sound settings stay the same?
Monday
Hey all,
I wanted to follow up with you. We are aware of the issue, and have just been informed that a fix will be coming in the next firmware update. We do appreciate your patcience at this time.
a month ago
Hi Ante71,
This is not the experience that we wanted you to have, let me help you out. A few things: when did your issue begin? Were there any recent changes before the issue started? What steps have you taken so far?
You can do a sequential reboot. First, unplug your Nest Hub for 30 seconds, then do the same thing to your Wi-Fi router to refresh both devices and your Wi-Fi signal.
Let me know how it goes.
Juni
a month ago
Hi Juni.
Thank you for the reply.
I have had an old Google Home for man years and then I thought I would uppgradera. So a few days ago I bought 4 new Google Nest Audio. I noticed this problem right away when I testet them for the first time. I do not have a Nest Hub. I only use the Google Home app on my Samsung phone.
a month ago
Thanks for the details and I’m sorry that you are still experiencing the issue. Have you tried the troubleshooting steps that I suggested? I also want to confirm the adjustment that you are doing is for individual Nest Audio or via speaker group?
Looking forward to your responses.
Juni
a month ago
Hi.
I have rebooted my wifi router but I don't own a Nest Hub so I can't reboot that. Yes I have made the changes induvidual on ever Nest audio speaker.
4 weeks ago
Hi Ante,
Thanks for confirming. You can do a factory data reset to put your Nest Audio back to their default setting and set them up again as a new device. Once done setting up, observe if this will make a difference. Check the steps below on how to reset your Nest Audio.
Here’s how to do the reset. On the back of your Google Nest Audio, switch the mic off. The LEDs will turn orange. It will say "The mic's off" then press and hold the center of your Google Nest Audio, near top. After 5 seconds, your Google Nest Audio will begin the factory reset process. It will say, "You're about to completely reset this device. Release to cancel" then wait for the chime.
Check this link for more information.
Keep me posted.
Juni
4 weeks ago
Hi.
I have now restarted my router and Google mesh. Reset all 4 Nest audio and installed them again but I am sorry to say that I still have the same problem with the equalizer.
4 weeks ago
Hey Ante71,
Chiming in, is it working before? Do you have other Google Nest speakers? Do you experience the same issue when adjusting their settings? What are the firmware version of your devices? Follow these steps below to know-how:
Muddi
4 weeks ago
Hi Muddi!
The 4 Nest Audio speakers are brand new. I have one Google Home, one Nest Mini and two Google Mesh and they work fine and do not change the bass or treble. The firmware system on all four Nest Audio is 324896 and the firmware cast 1.56.324896.
4 weeks ago
Sorry, the Mini is not a Nest, it is the earlier Google version.
4 weeks ago
I have the same issue, i have to reset the equalizer every song. I'm using deezer and i have a nest audio FW cast 1.56.324896
3 weeks ago
Thanks for providing the information. We'd be happy to take a look into this for you. Please fill out this form with all the needed information then let me know once done.
Muddi
3 weeks ago
Hi Muddi.
You wrote folks and not just Palmss972.
So should I also fill in the form?
3 weeks ago
Hi Ante71,
Thanks — we got your form and we've escalated it over to our higher level of support for further review. Please keep an eye on your inbox as someone will get back in touch with you soon.
Princess
2 weeks ago
Thanks for all the information. To confirm, is the issue isolated when playing music on paired devices only?
Muddi
2 weeks ago
Hi.
I have tried both paired and non-paired, and it doesn't matter. Same problem.
3 weeks ago
Same issue here
3 weeks ago
Hey Dhag,
Could you list down all your devices, together with the current firmware version. Also, what are the steps that you've done?
Muddi
2 weeks ago - last edited 2 weeks ago
Hi , same issue here.
2 stereo paired nest audios, google home version 2.62.1.15. Both speakers on version 1.56.324896.
Every pause or song skip the equalizer resets to the default settings (app still shows my personal setting) and once you tap on either bass or treble the equalizer starts working, until the next pause stop or song change.
I just purchased a Nest Audio. I have the same issue as Etay.
Steps to Reproduce:
1. Play song on Spotify Mobile Phone App. Home app is linked to Spotify.
2. Open Nest equalizer from Home app. And adjust equalizer settings.
3. Skip to the next track. (Also happens if I Pause the track and then Play). Equalizer adjustments from step 2 do not stick on the next track. The sound reverts back to the default. (However the sliders on the equalizer show my adjusted values in step 2)
4. To activate my preferred equalizer settings again I have to change either of the bass/treble settings. However Nest goes back to default equalizer settings when the next track plays. [Annoying]
Firmware: 324896
Cast FW: 1.56.324896
a week ago - last edited a week ago
a week ago
Hi Muddi, I do not have any other Google device other than the Nest Audio.
a week ago
Hi Muddi.
As i wrote earlier in the thread, I also have a Google Home and a Google Mini and they works fine
a week ago
Thanks for the information. I'll forward this to the team and will update the thread once I have more information to share.
Muddi
Monday
Hey all,
Wednesday
Hi! just wanted to add my +1 to this - i use Deezer on PC and Pixel 6 Pro through Home App and the EQ resets every single time i pause, track changes or track skip - quite annoying :(((( not sure why - so i am watching this thread for more info!!
a week ago
Hi Muddi,
I have many devices and a display. Only the nest audio has this issue.
2 weeks ago
I have exact same issue. Have to go into EQ each track to make it sound how it should. Never holds the setting on the next track. Done a factory reset and readded. Nothing helps. Not sure if it the home app or the speaker
