Google Home display won’t adjust volume when I tell it to, it adjust my TV volume instead How to fix
Rdianco
Disclaimer: This thread was migrated from our previous version of the Google Nest Community.  You can continue to receive updates on your thread issue here or simply ask, browse or more in the new Google Nest Community.
Original Poster: James Beck 4196
Adjust the volume on the home display. When I say “increase volume” even if my TV is off. It adjust volume in the TV. Same for “decrease volume” or “set volume to” I've tried saying “adjust your volume” and still it resorts to adjusting my TV volume. When I built routines specifically saying to adjust volume of the display those also are adjusting my TV volume. The only way to change the volume on the display is swiping up and tapping the volume.
Rdianco
I see on your image you are using a third-party Roku device in your bedroom.
Please contact Roku support about your issue.
- From James M. (Diamond Product Expert)
