10-07-2021 08:34 AM
My Google Home speaker seems to be stuck in a boot loop.
When I power it on, the LED on the back (between Mute button and Google logo) lights up white, but the main LED circle on the top of the device never lights up. See: https://ibb.co/DG2KqJy - It is unresponsive and does not show up in the Google Home app.
I tried to factory reset, however pressing the Mute button for 15 seconds (or longer) has no visible effect. Power cycling the device multiple times as suggested here has no effect either. The LED on the back does not change color at any point.
Is there a way to hard reset the device or flash fresh firmware? I noticed the hidden microUSB port...
@mod: Sorry about the labels. I don't think they fit very well, but were the closest match IMHO
10-21-2021 11:57 PM
I have the same issue - tried rebooting/factory reset with no luck
