4 weeks ago
hi I was connected previously to my Bluetooth speaker from my iPhone using Bluetooth. I placed the nest audio speaker into pairing mode connected successfully until the nest stops playing audio and I tried to reconnect but no matter what I do I cannot see the speaker in my Bluetooth settings anymore
4 weeks ago
That can happen sometimes. Try forgetting the Nest Audio in your iPhone’s Bluetooth settings, then reboot the speaker by unplugging it for a minute. After that, say “Hey Google, Bluetooth pairing” or enable pairing mode in the Google Home app. If it still doesn’t show up, a factory reset usually fixes it.
3 weeks ago
Hi DBrown,
Thanks for posting in the community! I understand that you're no longer able to see your Nest Audio in your iPhone's Bluetooth settings after it initially connected and then stopped playing audio. It's certainly confusing when a device you just connected to suddenly disappears from your Bluetooth list. I'm here to help!
To find the best solution, I have some questions for you:
I appreciate your input, @Anna18.
Please keep me in the loop!
Sincerely,
Juan
