Google nest hub display problem
Elaine3
Hello I have had my google meet hub for around about 1 week and I am having a problem with my linked or connected apps displaying when I swipe up to show me the menu bar.And yes I have made sure it is on the correct WiFi and there is nothing wrong with the placement.it shows no apps and I am really struggling please could someone be so kind to help me?
thank you
tajennifer
Hi Elaine3,
Thanks for posting. I understand that you are experiencing issues with your Google Nest Hub because not all your apps are showing up on the menu bar. I appreciate the information that you provide about the WiFi connection. I need to confirm some information to provide the best solution:
  • What apps are not showing up on your Google Nest Hub?
Please keep me posted.
Jenny
