10-11-2021 03:24 PM
Over the past couple of weeks my Google Home Hub Max has repeatedly shut down and rebooted. A little while ago it rebooted and got stuck on the four colored circles spinning and hasn’t stopped.
10-11-2021 03:39 PM
That's odd behaviour... Try a factory reset and see if that clears it up.
10-12-2021 11:17 AM
Thanks for the response. As it turns out it started working after I unplugged it overnight. So far so good.
10-19-2021 02:08 PM
Hi All,
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
10-18-2021 01:52 PM
Hi All,
First, thank you Ashepherdson for finding a solution!
Hi EllaBooBella, just wanted to check in. Just double checking, has your issue has been resolved? Please keep us updated, thanks!
