How do we connect a smart blue tooth light bulb?
JosephWayne
My issue is a light bulb called [ a bove ] at least that's what I think the name is.  How do I link it?  I've done it with my last phone but, I moved, changed and upgraded my phone. And I can't get it detected (it doesn't show up).
KDusich
Have you reset it?  I know the Cync ones are done so by turning light on and off like 5 times with one second intervals between .  Look up manufacturers instructions on resetting bulb then try.
Juni
Thanks for bringing this up to our attention @JosephWayne. A few things: were you able to try the steps suggested by KDusich? What is the make and model of the light? Did you use Google Home app to link it before or its native app?
Thanks for the help @KDusich.
Keep me posted.
Juni
Azarco
Checking back in to see if you still need help with this. Feel free to respond to this thread if you have additional questions or concerns and I'd be glad to answer it for you.
Alex
Azarco
Hello everyone,
Alex
