02-25-2023 12:17 AM
Hi, I’m seeking advice on making my Google home speaker (an original flower pot shape) sound an alert when my mobile phone rings indicating an incoming call while I’m home. I have a Pixel 6 Pro on Android 13.
I’ve spent some time reading, asking Google Assistant & looking for an app but have not been able to make any progress.
Any advice would be appreciated.
Cheers
03-01-2023 01:49 PM
Hi Gr4ndp4,
Good question, we currently don’t have that feature. We're always looking for ways to improve. I'd suggest you submit feedback about it, here's how.
You can use your number and create a Duo account and link it to your Google Home app so you can receive phone calls using your Google speaker instead. Check the steps below for guidance.
I hope this helps
Juni
03-02-2023 07:33 AM
Hi, @Juni, thanks for your advice, much appreciated. I will post a feature suggestion.
Cheers
03-02-2023 09:57 AM
Thanks for submitting the feedback as every bit of feedback helps a ton. I’ll keep this thread open for one more day. If you need further help, let me know.
Juni
