"Hopefully somebody can help me here because when I change the color of my lights in the color palette to blue then go back to the main screen which shows what light I'm using and what color it is, there are six little color palettes to adjust the coloring of the light color. These pallets should be in the same color field as the color I'm using but they don't change they remain the same color as before i.e. white gamut. I've tried many variations and it still doesn't change. Can anyone explain to me if there's a step that I'm missing or what I should do? I thank you in advance. https://www.googlenestcommunity.com/t5/Home-Automation/Color-change-to-Orein-smart-light-does-not-sh...
