My mini nest radio reception keeps cutting out
REvans6659
My mini nest speaker keeps cutting out. (I have 3 in different rooms) I have rebooted all and turned router off and on. What should I do next?
AnnaV
Hi all,
Thank you for getting back to me and for the follow-up. I appreciate the effort you’ve put into resolving this, and I’m happy to continue assisting you.
We need you to send feedback via voice command by following these instructions:
Turn on device reports:
  1. Tap and hold the device tile in the Google Home app.
  2. Tap Settings > Recognition & sharing.
  3. Turn on Send [device model] device usage and crash reports to Google.
Send feedback via voice command:
  1. Say, "Hey Google, send feedback."
  2. When prompted, mention the keyword "GHT3 23803 BBC radio playback issues."
This feedback will be essential for our engineering team to investigate the matter and work toward a stable fix.
I hope this helps!
Anna
94 REPLIES 94
@AnnaV I've done "Send Feedback...  GHT3 23803 BBC radio playback issues." for 2 of my 3 Gen 2 Nest mini devices shortly after they each individually had failure as described. First one at approx 2026 May 06 T06:25:00Z (I can't use ISO8601 format for the time in this reply!)
Hazey-ZA
Same issue. Works on TuneIn radio, but direct bbc stream has buffering issues for past few weeks now. Can not get it fixed. Definitely an upstream issue that BBC needs to assess and fix. Ruining the experience
Bubbatryo
Same, can't use BBC sounds with nest anymore, cuts out after about 20 seconds
Dannad
When I say 'Hey Google, play Radio 4/3/whatever' it plays 20 seconds of radio, then nothing for 10 seconds. Then it plays the same 20 seconds of music
Yes, I've tried rebooting, factory resets, re-adding to the network. Yes, I know the ecosystem is broken because Google only cares about AI now. Yes I realise none of the product teams talk to each other.
I'm not interested in 'advice' that implies it's my fault, what I want is a timeline for when Google are going to fix it - it's your responsibility.
Dannad
...and don't get me started about how YouTube M*sic is these days...
David99
I've got exactly the same issues. Only bbc sounds affected and all 4 of my nest mini speakers are doing the same boot and loop audio and only happened now Gemini is involved. I know this because of the "different" American accent!
MEX-
I have the same issues!!!
BarrySSG
Same as well. I found that my cast firrmware is out of date and it will not update.
Car67
Yes me too, this exact same issue. Started over the last weekend.
Angelabdc
Exactly the same thing happening with my speakers. Will not fix with reboots or resets
BarrySSG
My 1st Gen mini is working fine on the latest firmware but not my 2nd gen one
Car67
OK so I think we'll get somewhere if we just go down the chat route when reporting this, rather than anything else. I've had a very productive online chat, which is now being escalated to 2nd line because nothing they suggested solved the problem. If we all report it this way, we might get something done. Cheers.
Dannad
Good to hear! The BBC possibly has more leverage to get it fixed than I do!
