Nest Audio replacement power supply
Sheesh
Is there any place that I can get a replacement power supply for my Nest Audio?  One of my power supplies burned up during a lightning storm.  The speaker still works fine as I plugged it into a power supply from another Nest Audio to test the speaker.
Alex_S
Hi Sheesh,
I’m sorry to hear about what happened. The Google Store doesn’t have a replacement power supply for Google Nest Audio, but you can check any local electronic stores for the same specification.
Kind regards,
Alex
