Nest Hub 2 does not connect to wifi
tosanen
Our Nest Hub 2 does not connect to wifi. We changed to new router and used the same wifi name and password. But as it did not connect, I had to do a deafult setting of the Nest Hub 2 and then also changed name of wifi and password. Followed the instructions, but the hub says I can't connect to wifi. It says I have to control the password. I have checked, the password is correct,
I have restarted the hub 10 times as well as default set 10 times.
I have tried turning off Guest network on router.
I have tried 2.5G and 5G by turning off on of them.
I have reinstalled Google Home app on my android.
I have also tried with my android pad and my dauthers iPhone 12.
It fails to connect the hub to the wifi.
What more can I try?
0 REPLIES 0
