12-27-2022 09:22 PM
Am I able to connect nest audio (2 speakers) with Sony z8h (Google assistant integrated) without using chromecast. If so, can I get info on how to do it. I will greatly appreciate it.
01-01-2023 04:16 PM
Hi Ueuo145,
Thanks for posting.
If you want to control your Sony Bravia Z8H using your 2 Nest Audios, then a Chromecast dongle or a built-in Chromecast or built-in Google Assistant is needed. It would be best to have a Chromecast or built-in Chromecast for you to be able to maximize the features that you can use with your Nest Audios and your TV. By the way, could you double-check if your TV has a Chromecast built-in to it? If yes then make sure all your devices are set up on the same Wi-Fi network. Click the link below and follow the steps to link your TV to your Google Home app:
Hope this helps.
Kind regards,
Dan
01-04-2023 04:26 PM
Dan
01-05-2023 05:48 PM
Hello Ueuo145,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Nest speakers and we'd be glad to assist you further.
Princess
