Nest cam battery notifications on hub and speakers
Manimekalaianan
Alerts and notifications of Nest cam battery does not appear on hub display or speakers.
Also cannot use 2 way talking from the display.
Kindly update whether it is possible
Princesss
Hi Manimekalaianan,
Glad you reached out.
A few things I'd like to ask -- Is this the first time that you have experienced this with your notifications? Also, are there any changes made on the settings prior to this? If no, you can check these settings for Alerts and notifications:
Make sure the mobile device is connected to the same Wi-Fi or linked to the same account as the Google Nest or Home device.
  1. Open the Google Home app .
  2. Tap Settings > Notifications > General notifications > Critical alerts On.
Lastly, updates are sent automatically on your device and is sent OTA (over-the-air) which means that as long as the device is plugged in and connected on a stable WiFi connection, it will automatically update itself.
Let me know if you have questions by responding to this thread.
Princess
Princesss
Hi Manimekalaianan,
Chiming in to check if the steps I provided worked on your end?
If you still need assistance, please feel free to respond to this thread and I'll assist you further.
Princess
Hey Manimekalaianan,
I wanted to check in, and ensure you are good to go. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
