3 weeks ago - last edited 3 weeks ago
Hello, I have a nest hub generation 2 that I've had for 3 years and it's been working fine showing my wyze doorbell cameras when someone pushes the button. For about a month now it has not shown the camera but it does announce someone's at the front door. There is a white flash of the screen before it announces.
I have factory reset the display and the home app twice now with no luck and l reinstalled all my devices on the home app and I have set up triggers like I did 3 years ago to allow the doorbells to show on the hub and I can't figure it out.
Any help would be appreciated.
Hi @MJMGN,
I appreciate all the troubleshooting you've already done with your Nest Hub 2nd gen. Based on the information you've provided, it seems the problem is with the Wyze camera itself. I recommend contacting Wyze Support directly, as they are best able to help you troubleshoot your camera.
Feel free to keep us posted if you have more questions.
Gabriela
3 weeks ago
Thank you for getting back to me. The weird thing is that it's been working for 3 years with the same camera now within past month or two it quit working. I will check with them and see what they say unless you can think of something else.
