01-28-2024 11:34 AM
I have some aqara temperature/humidity sensors added to my Google Home devices. These can not display the temperature on the nest hub even if they work perfectly in Google Home app.
Asking assistant for the temperature in a room gives me the correct temperature by voice, but the screen shows a screen with no temperature where the value ring is just loading forever.
Asking for humidity shows a a screen with the correct value as expected.
It might also be related, all temperature sensors show up in the nest hub as "Refer...0" when manually clicking through rooms in the nest hub.
