12-01-2022 05:28 PM - edited 12-01-2022 06:09 PM
For the last few months I have had an issue where my Nest Mini’s repeatedly say “there’s been a glitch, try again”. Whenever I factory reset the device they begin working again for about 5-10 minutes and then again get stuck. I contacted support and was told to buy a new device however when I did this, the same thing occurred. I was told that there might be something with my wifi settings that could fix this but internet provider is not a Google nest mini expert and does not know how to help. I have repeatedly asked for further help from Google support and my emails have been ignored. Does anyone have any ideas on what I could do fix this??
Other notes- this was a gradual process in which first it only happened on one device and factory resetting it solved the issue. Then it stopped resolving the issue and then eventually started occurring on the other device as well.
12-06-2022 10:34 AM
Hi Help5697,
Thanks for posting and for being a step ahead of us.
That certainly hasn’t been easy for you. Let’s check what’s going on. Since the issue is happening on multiple devices now, you can check with your internet service provider if the AP isolation setting is enabled on your WiFi router. This should be disabled. Could you also provide the case number when you contacted our support team so we can further check for you?
Juni
12-09-2022 12:07 PM
Buzzing in — do you still need our help? Don't hesitate to reach back if you do.
Juni
12-10-2022 10:34 PM
Hey Help5697,
Just bumping in to make sure that you've seen our responses. I'll lock this thread if we won't hear from you in 24 hours. Feel free to create a new one if you have more questions or have other concerns in the future.
Muddi
