08-29-2023 05:03 AM
I have a Hisense 75" Class - A65K Series - 4K UHD LED LCD TV with google tv os built in and a Denon AVR S760H 7.2ch 8K AV Receiver with a Chromecast with google tv.
My tv is outside and my a/v is in the house and I want to just play the audio from my tv to my av unit because I have wired speakers in my backyard. I made a speaker group off my tv and added the Chromecast and my nest speakers as well and no sound comes out. this is the only issue i have all my other app work fine in the group if I pick another source i.e. Pandora ect.
PS I cant use BT to far from the source and the same with running a HDMI cable since my tv can roll to other spots. I need the connect to be wireless
Thanks for the help in advance
08-29-2023 05:28 AM
Experiencing no audio while casting to a speaker group might be due to network issues, incompatible devices, or misconfigured settings. Check device compatibility, network connectivity, and ensure audio output is properly directed to the speaker group for a solution.
