Playing BBC Radio on Home Hub
Block
I have always been able to play BBC radio stations on my Home Hub by asking 'play radio 4', but today it just responds 'i can't do that on here'. What has changed?
Muddi
Hey everyone,
I have some great news to share! This issue on BBC Radio should now be resolved. You can now go back to listening to your favorite BBC station on your speakers/display as normal. If for some reason you’re still experiencing problems, please try rebooting your devices to refresh the settings.
Muddi
764 REPLIES 764
  • I am too. In addition not being able to use Google nest home to play bbc4 all my smart speakers have appeared in duplicate and I couldn't cast BBC sounds. Fixed this problem by deleting Google home and reinstalling Ng. Everything still in duplicate but I can now vat but not use nest to play radio 4
ColinT1
For vat read cast
JaneML
I have uninstalled. But have managed to get it to listen and play bbc stations on my Sonos speaker. Just not on the google mini. Plain bizarre!
Unfortunately not working for me, unsure how to resolve or get any update
I haven't been able to get BBC radio stations to play for the last few days either. Noticed a few people above said theirs was back, mine still isn't working. Says the same thing as yours.
Princesss
We're sorry to hear about this experience. There's an ongoing conversation referring to this. We'll go ahead and move this conversation to the main thread for updates.
Princess
All we seem to get in response is always from you Princess. It's always the same message which is disconcerting and makes me wonder if anything IS being done your end. I'd love a reply to this message...
Muddi
Thanks for posting in the Google Nest Help Community. I've duplicated this thread to a similar trending issue on this link. Our team is aware of an issue affecting some users and are currently looking into the issue at hand. I recommend following the main thread for updates and additional steps.
Muddi
Shelly_D
This has been going on for over a week now. When do you anticipate the problem will be resolved? Thinking of just going out and purchasing an Alexa instead.
My Google mini has stopped playing bbc radio stations. Any ideas?
Ours stopped playing any bbc radio stations over the weekend as well. If anyone has found a fix for it that would be great!
Link below has stuff on the problem, however nothing that gives a fix, hope it helps for now
https://www.googlenestcommunity.com/t5/Speakers-and-Displays/Bbc-stopped-working/m-p/390282?search-a...
Try logging a report to BBC Sounds, the more the better I guess. Link below
https://www.bbc.co.uk/sounds/help/contact-sounds-help/#/Need%20more%20help?
Mine stopped some time yesterday. It could play Radio 3 first thing yesterday morning (2023-04-03) but by the evening it started responding "I can't do that here, but you can ask me to play it on one of your other devices"
Non-BBC stations still stream fine btw.
This seemed to happen also a couple of years ago looking at past posts. The advice is to tell your device to "send feedback. Device won't stream BBC radio"
If enough people do it they might fix the update.
@Dandan62Have just sent that feedback. Let's see how long it takes...
SteveL1
Same problem here, bbc radio stations stopped working today.  Have factory reset google speakers and reset router without a change.  All other stations work ok.  Can Bluetooth bbc from iPlayer on phone to google speaker which is a faff, and shouldn’t be required.  On the bright side Ken Bruce is on planet radio so perhaps I don’t need bbc.  Have sent google feedback.
If I say "play planet radio" Google says that's not available on Planet Radio, it's so screwed up!
Whatever happened to this ground breaking AI, it's more like AS, Artificiall Stupidity 🙂
SimonM0
In the last 24 hours , my google displays have refused to stream BBC Radio. When I ask it to 'play BBC ?', I get the following response   'I can't do that on here but you can ask me to do it on other devices'. Feedback sent, but despite Google being a huge organisation, based on previous experience with them, when they get the software wrong, I don't hold out much hope of it being fixed soon.
Tigrou52
I am having the same problem - what's going on!!
Google aren't even acknowledging that there is a problem
Emsly22
BBC radio stations not been working since Sunday but other radio stations are ok. I can cast BBC sounds to the speaker but when I ask it to play radio 2 google says “I can’t do that here but you can ask me to play it one of your other devices” - it won’t.
I have found this article on the BBC but not sure it’s relevant but would explain the stop the BBC stations https://www.bbc.co.uk/sounds/help/questions/recent-changes-to-bbc-sounds/shoutcast-closure
SimonM0
The issue I had with playing BBC radio on all my Google devices (display hubs) has been resolved, so everything is now working as it should.
Thank you Google Support ?
Thanks for the heads up. Just checked and it's working for me too
Did you do anything to get it back? Mine's still not working.
The only thing I did was to use the send feedback feature that @Dandan62 mentioned but nothing else, and it just started working again this morning. Have just checked it again now to make sure there hasn't been a recurrence and can confirm it's still working for me.
I'm away from home so can't test my 3 speakers but I'm staying with someone and there's is now good.
I'm not clear at what end bbc/google the problem was.
Could try asking.google to play your station and then state "on bbc sounds".  If like me trying everything to fix, you may have switched something in your settings?
Final thought, perhaps leave it a day, doesn't make logical sense but people loosing bbc seemed to happen over a few days?
SteveL1
All back to normal this morning.  Many thanks to bbc and google for sorting it out 👍
SteveL1
Unfortunately, I spoke too soon and BBC radio channels have stopped working again.  My google home tells me “Sorry, I can’t do that yet”.
CaveDog
A common problem right now.  For a workaround, say "Hey Google, take me to the BBC sounds website".  On the website, use the on screen keyboard to log into BBC, then choose your radio station and it will play.  It's clunky, but it works.
JC43
thanks for trying, but no good if you don’t have a hub / screen.
Speaker1
That's a fix to play the station on your phone right? I can do that already, it doesn't fix the mini playing the BBC from a voice command or am I missing something?
Don't be a **bleep** mate.
CaveDog
It's for a Nest Hub.
Brock1
I have four different Nest speakers and until about an hour ago, they all played BBC Sounds live radio. Now none of them will do that. The strange thing is to speakers are in entirely separate houses. Everything else works. I get the message that says” I can’t do that, but I can play it on one of your other devices.”
If the BBC has stopped working for you, there are a few things you can try to troubleshoot the issue:
  1. Check your internet connection: Make sure your internet connection is stable and strong. If your connection is weak or intermittent, it may be causing issues with streaming content from the BBC.
  2. Clear your browser cache: Clearing your browser's cache and cookies can sometimes resolve issues with streaming services. Try clearing your cache and cookies and then restarting your browser.
  3. Check the BBC website status: Check the BBC website status to see if there are any known issues or outages affecting the service. You can do this by checking their social media accounts or by visiting a website that tracks the status of popular website
If BBC Radio has stopped working on Google Home/Nest devices for hundreds if not thousands of us, this suggests the problem is not local to our homes but nationwide.
And how exactly do you clear the browser cache on a Nest Hub? (rhetorical question)
Its none of those
Farid, I know you think you are being helpful biut think you must be a bit late to the issue. Everyone has tried everything by now and NOTHING WORKS! Thanks though.
I'm hoping this is a temporary glitch. I started with the same issue this evening. If I ask for a non-bbc station to be streamed, it works without problem. It is still possible to cast from the BBC sounds app on the phone if that helps for now.
