03-23-2025 09:55 AM
Hi - is anyone aware of any current problems with Nest Audio devices? All my Nest Audio devices have started playing up. I've tried all the usual factory resets etc. but with no success. Nothing has changed on my internet/LAN and I've checked the upnp/multicast settings for the router. I can complete the normal Nest Audio setup using Google Home but it hangs on final step 'configuring your nest audio' and then fails. After the fail, the device does show in Google Home but when you go to device settings for the speaker it shows an error message 'some settings are unavailable at the moment'. Is there a problem with Google Nest services at present? Are these problems related to the recent problems that Google have been reporting about Google Chromecast not working?I've tried running upnp tests on my LAN. My Chromecast device shows up but none of the Nest Audio devices are listed. Would welcome guidance on how to proceed. Thanks.
03-26-2025 06:28 PM
Hi martinix,
Thank you for posting to our community.
I’m sorry to hear that all of your Nest Audio devices have started acting up. I appreciate you providing important information such as the troubleshooting steps you’ve tried and the behavior of your devices on your Google Home app while you try to set them up. No worries; it is my pleasure to assist you with this inconvenience.
Before we proceed with further troubleshooting, let me ask you a few important questions:
Thank you for your time and attention. I look forward to your response.
Virna
03-31-2025 07:20 AM
Issues have got progressively worse over last 3 months. Rapid deterioration in past month.
1-20ft from Mesh access points.
For Nest 2 devices – 4 leds on front light up in response to voice command. Leds display when volume adjusted.
No changes to wifi network.
Yes
System Firmware: 456944 and Cast Firmware: 3.75.456944
For Nest Audio Devices: Switching mic off. Lights turn orange. Pressing and holding the center of the Nest Audio, until device will begin the factory reset process. After resest confirmation readding device to Google Home.
