02-01-2023 03:55 AM
Am eliminat dispozitivul din Google home și nu pot să-l adaug din nou pentru că îmi cere să fac resetarea din fabrica
02-04-2023 04:30 PM
Hi adymro,
I'm sorry to hear that you had to go through a factory reset to reconnect your Nest Hub Max. It is very important that we do it especially if there are changes on your Wi-Fi or if you've moved location or in this case, removed from the Google Home app. A few questions: why do you have to remove your Nest Hub Max from the Google Home app? Are there changes done to your Wi-Fi or your account or address?
Doing the factory reset will revert your Nest Hub Max to its default and original settings, please follow the steps below to avoid slight complications when setting it back up.
Keep me posted.
Dan
02-07-2023 04:54 PM
Dan
02-08-2023 05:18 PM
Hello there adymro,
Dan
