Says needs to be activated
MarkE
Nest audio says needs activation before set up
46 REPLIES 46
JoshH
But I only have a Pixel phone. This isn't an inconvenience, this is completely unacceptable. This is a Google product that I can't set up using a Google phone? Surely you can see that doesn't make any sense. Do better! What is a solution that I can set up my device using my Google Pixel.
Azarco
Hey JoshH,
We understand. Could you fill out this form so that we can check this out with our team? Let us know once you're done.
Alex
JoshH
I completely the form, in which I explained the same issue that has been explained here. Please advise what will be different. How long do I have to wait to activate the product I bought? Should I just replace all of my Google products? That would certainly fix this problem. And that's definitely more of a solution than you are offering. When wil this be fixed?
JoshH
Another day gone by. Any updates?
Princesss
@Sadeep, We've received your form-- thanks for filling that out.
For those who are still experiencing the same issue, we recommend to try and set up using a different phone. We'll keep this thread open and will wait for updates.
Princess
JoshH
I can't believe that the only solution to the problem of, "I can't set up my Google product with my other Google product" is to find a non-Google product. I will find all non-Google products in the future and I will encourage everyone I know and come in contact with to do the same. This is absolutely horrible customer service.
Sadeep
Have the same problem. Support is not giving a solution because they deactivated setting up of speakers using Pixel due to an ongoing Sonos lawsuit. It seems that the only solution right now is to use a non-pixel Android phone to setup the device. Just so the support here knows it is extremely frustrating and privacy-compromising to use someone else's phone to set up a device in my home.
