Terrible delay when using stereo pair
Yento
I have two Google WiFi speakers an wanted to use them as stereo so I could use them as a part of a surround sound system. However, when I use them as a stereo pair, there is a huge delay of a couple seconds. When I separate them again there is a minor latency so the problem lies with the stereo pair. Is there a solution, and if not, are there plans for working on one?
kind regards,
Yento
Azarco
Hi Yento,
We hope you were able to get the help you need but if you're still having trouble, you might want to check out this link. If the issue persists, feel free to submit another post and provide as many details as possible so that others can lend a hand. Hope this helps!
Kind regards,
Alex
