Where can I get a Nest Audio power cable replacement in UK
Lyra_Lycan
I purchased two Nest Audio speakers from Europe (EU plug), but using EU to UK adapters is horrible, as the connection is loose and occasionally breaks contact (powering off). I'd much prefer to swap or replace these with genuine UK power cables. Anyone know where I can get these?
Thank you in advance,
Lyra
Dan_A
Hi Lyra_Lycan,
Thanks for posting.
You can check out this guide about Nest devices specifications. You can buy the power adapters in stores near you as long as the criteria are met.
Hope this helps.
Dan
Dan_A
Hi Lyra_Lycan,
Thanks for posting.
Hope this helps.
Dan
Lyra_Lycan
Thanks @Dan_A - with that info I've found some power adapters that should be perfect! Thanks @Jake - Everything is good 🙂
Princesss
Hi Lyra_Lycan,
Thanks for the update. Glad to know that everything is all sorted out.
Since this has been resolved, we'll consider this complete and will lock the thread in 24 hours. Feel free to start a new one if you need assistance with your Google Nest speakers and the team would gladly help.
Princess
I wanted to check in and see if you managed to see Dan's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
