03-31-2024 08:20 AM
Virtually every time I use one of my Google Home devices to access Google Assistant, to operate a smart connected device, for example, I get the response "There was a glitch. Try again in a few seconds." It works a few seconds later, only for the same issue reoccurring again almost every time I use it.
Other devices don't have the issue.
I've reset the device.
I've read other response[s] [https://www.googlenestcommunity.com/t5/Speakers-and-Displays/quot-There-was-a-glitch-quot-on-first-t...] to the same issue, with the solution being "disabling IPv6 on router", but I went to the advanced settings on my router and IPv6 wasn't enabled.
I'm completely fed up with it and ready to smash the thing.
04-01-2024 10:15 AM
Hi killermouse1974,
Thanks for reaching out. Sorry to hear you're having issues using Google Assistant.
I suggest you follow these steps:
Let me know if this information helps.
Jonathan
