10-21-2025 03:25 PM
I have four Google Nest Audio Speakers, two as a stereo pair and two others. I haven't had any problems with their connectivity or setting them up so I wanted to add two Google Nest Minis to the family and I can't get either of them to connect.
I get through the initial set up screens and then finally I hit:
Configuring Your Nest Mini
Hang tight it shouldn't be more than a few moments
I can't get past this section. The next screen is always
There was a problem setting up Nest Mini
For help resolving this issue, visit the Help Center.
Between the Help Center and the message boards, this is what I've tried so far:
Rebooting the devices.
Rebooting and unplugging for ten minutes.
Restarting the router.
Restarting the router and unplugging for ten minutes.
Restarting my phone.
Restarting the phone, restarting my router, and rebooting the devices.
Connecting my phone's wifi to the nest mini wifi (but this doesn't seem like it could ever work because then I open Google Home and it has no real connection so all of my devices are greyed out and I can't connect to anything at all).
After finishing the semi-setup, the devices do appear in my Google Home, but there are things I cannot do:
Rename them
Pair them
Add them to groups
Reboot them from the App
I did manage to get sound out of one of them from Spotify, but then it "broke" all my other connections and now I can only connect to my Google Nest Audio Pair and neither of the single speakers will connect, so I'll need to re-upload them after I get ride of the Minis.
It seems unlikely that I have two Minis that don't work, so what other tricks did I miss that I should be trying? With this much trouble during setup though, I almost want to just send them back. It seems a bad omen and that I'll continue having issues...
10-24-2025 10:40 AM
Hi OverpricedVodka,
Thank you for reaching out to the community. I see you’re having trouble connecting your two Nest Minis to the Google Home app. I also noticed that after trying to move through the setup process, you received the error message, “There was a problem setting up Nest Mini. For help resolving this issue, visit the Help Center.” I can certainly understand how frustrating this must be. I appreciate all your troubleshooting efforts you’ve already taken. I’m here to help.
For better assistance, please respond to the following questions:
Please keep me posted on your findings.
Byron
2 weeks ago
Hi Byron,
What model of the Nest Mini do you have? (Here is a helpful article to identify the type of Nest Mini)
* Nest Mini 2nd Gen
Are you using an Android or an iOS device?
* Android
What is the Android or iOS version you’re currently running?
* Android version 16; One UI version 8.0
Is the Nest Mini powered on and directly connected to a power outlet?
* yes
What LED lights appear on the top of the Google Nest Mini?
* sometimes they're orange and sometimes they're white
What happens when you say "Hey Google" after setting it up?
* nothing
Has the Google Home app been updated recently?
* yes
Is the Nest Mini in the same room and within 15 - 20 feet of the device you’re using for setup?
* yes, about five feet
2 weeks ago
Hi OverpricedVodka,
Thank you for your reply. I appreciate all the detailed information.
Based on your previous answers, please follow these recommendations:
Step 1: Reboot the Wi-Fi router. Confirm the following:
Step 2: Uninstall, then reinstall the Google Home app.
Step 3: Connect the Nest Mini (2nd gen) to a hostpot.
Byron
