speaker power
Mattejay9
Hey just wanted to give you all a very good tip on how to replace your power supply for your google smart speaker.
If your unlucky to loose or damage your speaker power supply and are struggling to find a replacement or repair your damaged one.
Then stop and stress NO MORE!
You just need to have a power supply that’ll link up with this attachment piece but I’m pretty sure you’ll have something lying around the home that’ll fit this, most likely an old router power supply or laptop charger.
Anyhow once connected you push it into place give it a little push further if the light don’t come on but you’ll soon see it’s the one simply replacement that is the answer to all your frustration.
It’s here for less than £3
theirs other sellers with the same item up to £20.
So this is cheap cheerful and the solution
0 REPLIES 0
