10-24-2021 05:00 PM
I have worked on this nest doorbell battery for 2 days and it will not connect with internet or google home. What am I doing wrong
10-25-2021 06:17 AM
Hi @Hollie
First you are going to want to make sure that your bluetooth is turned on as well. When you get to the Home app and search for device, it will not automatically detect the doorbell battery. What you'll do is hit add device, then tap doorbell battery, then it will ask you to scan the qr code on the back. Have you gotten that far yet?
10-29-2021 10:32 AM
Hi, Hollie.
I just wanted to jump in real fast to see if you saw MrVacca's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
11-01-2021 02:46 PM
Hey Folks.
