07-01-2025 02:26 AM
Hello, I purchased my google battery about 4 months ago and for the first 3 months it held its charge well but it now only holds a charge for about a week. I'm located in Sydney and while it is winter the temperature at night falls to about 4-5 Celsius...which is within the operating range.
I would like to return it for a replacement, but when I try filling out the warranty form it says it no longer exists.
Can you please guide me on how to fix this issue.
Thanks
Michael
07-01-2025 06:32 AM - edited 07-01-2025 06:34 AM
You could try contacting Support:
3. Select your device from the dropdown, click "Other", then click "Next step".
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
