a week ago
I have a Google Nest Camera, and the charger broke off and is stuck in the housing because of the magnet. There is nothing sticking out to grab, so the only thing I can think of is to find a stronger magnet to suck it out.
Any better ideas?
a week ago
Hi @101gdn1
Hot glue possibly?? Glue a stick to the broken part to pull on when the glue sets??
Can you grab it at all with small pliers/tweezers etc?
a week ago
Nothing to grab. Glue is probably a good starting point. It's just that the surface is quite smooth and the magnet pretty strong.
I was just wondering if there were any other proven ways of getting it out.
Monday
Yep, let's see if any other other community members can offer ideas for this!
Wednesday - last edited Wednesday
Hi @101gdn1,
Thanks for posting in the community. I understand that the charger tip of your Nest Camera broke off and is stuck in the camera's housing due to the magnetic connection. Since nothing is protruding to grab, you're unable to remove it. You're wondering if a stronger magnet could be used. I appreciate the information you've shared. No worries, I'd be more than glad to assist you with this. To help with that, I have some questions:
@JillG, thank you for your contribution.
Any additional details you can provide will be helpful.
Jonathan
