12-19-2021 09:17 AM
I am unable to turn OFF my motion notifications on my outdooor nest cam. When I try to remove the “checkmark”, the screen loads and adds the checkmark again. I also have the opposite issue with my indoor camera, I’m unable to turn the motion notifications ON.
Im unable to turn the change check marks for motion alerts on/off. It’s like they are stuck to a default, and glitch when I try to change them. This is incredible frustrating.
I saw another post from Oct 2021 asking about the same thing, but thread was closed with no resolution.
Any suggestions?
02-02-2022 08:27 AM
I have the exact same issue and cannot figure it out, I have tried changing the location of my garage camera to bedroom or living room but it doesn't do anything, I just keep getting notifications every time a car drives by because the camera thinks it is motion
02-02-2022 02:30 PM
Its super frustrating. I cant believe such a huge glitch has been allowed to go so long with google. I reached out to customer service everywhich way I could think of to contact them, and got zero response. Best solution I have so far is to just turn off nest/google home notifications all together. Let me know if you figure something better out!
03-10-2022 09:50 AM
03-14-2022 12:02 PM
Just checking in to see if you still need assistance with this issue. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
03-15-2022 06:20 AM
Hi - yes I still need help with this, thank you! I cannot turn off the motion notifications for this one camera. When I try to deselect "All other motion" the check mark just won't go away.
03-15-2022 08:40 AM
Restarting and factory resetting your Google Nest camera or doorbell will have different results:
Restart: Keeps all your settings, and it should reconnect to the same Wi-Fi network. This is helpful if it ever becomes frozen, has trouble reconnecting to the internet, or isn't working normally.
Factory reset: Erases all your settings and options, and restores its factory default settings. It will not automatically reconnect to Wi-Fi and you'll need to set it up again.
You can find this information, plus additional information on this process here. Please let me know if you have further questions.
03-21-2022 10:11 AM
Hey Folks.
