Camera showing red light but recording still
mgnchungles53
My camera is showing a red light but is live and actively recording ? Any ideas? Checked all settings and seems okay .
AndersC
Hi @mgnchungles53,
Thank you for posting in the community. I understand your camera is showing a red light but is still recording, which makes it confusing to know if it's working properly or not. I'm happy to help.
Could you tell me the brand and model of your camera with the issue?
If you have a Nest camera, depending on the model, it's likely that the camera's LED is not working properly or the camera has insufficient power to work correctly. In that case, I recommend trying to connect it to an outlet with more power.
You can learn more about this in the article Nest camera and doorbell lights and sounds.
Keep me posted.
Anders
