11-22-2021 05:42 PM
Just installed the Nest Cam with floodlight. See both the light and the camera as separate items in Google Home. I have set the flood light timer to 1 minute and high motion sensitivity. My question is can I set the light to 30% brightness (when it turns dark) and then 100% when it senses motion? I would like the always on at night feature but don’t want it 100% bright unless needed.
11-22-2021 05:43 PM
Terrible subject line…sorry!!
11-27-2021 06:34 PM
I'm wondering the same thing
11-29-2021 10:32 AM
11-29-2021 10:57 AM
Would love to know if this is possible? Our light is set to 100% now (via Google routine) from Dusk till Dawn as I want a light on during the night. BUT - would love for that light to be at 20%(ish) and then turn to 100% for motion events and then back to 20% based on the timer settings. Seems reasonable- but don’t see a way to do this yet
12-27-2021 11:42 AM
I was just coming on to find this out as well seeing how this is very commonplace on floodlights and the one I'm replacing would do that.
Dusk would put the light on at 50% and motion would be full brightness for a time of 30 seconds to 5 mins.
01-04-2022 12:22 PM
So sorry for the delay! The answer would be that no, you cannot turn on and off your floodlight as it is motion based, and/or based on the sensor. I invite y'all to check out this article on how to change the settings and which ones can be changed for the floodlight. Please let me know if you need further assistance.
11-29-2021 10:38 AM
Still waiting...
02-10-2022 12:51 PM
02-14-2022 09:22 AM
Hey Folks.
02-10-2022 02:07 PM
02-10-2022 02:17 PM
Thank you so much for bringing this up to my attention! I like that idea, and I could see how it could be helpful. I will go ahead and submit this feedback forward for you. Thank you for all of your patience.
Please let me know if you need further assistance on this issue.
