3 weeks ago
Can’t find garage door detection on indoor camera just boiught and installed
3 weeks ago
We don't use that feature, but is this Help topic of any help?
3 weeks ago
Also, this is not documented in the Help topic, but if your camera is a 1st gen indoor camera, you have to "transfer" it from the Google Nest app to the "Public Preview" version of the Google Home app.
2 weeks ago
Maybe this will help:
Garage door detection is a feature that's currently supported in the US and Canada only. If you have a 1st gen Nest Aware subscription, you need to upgrade to a 2nd gen Nest Aware subscription and have a supported camera model before you can use garage door detection.
And it ONLY works in the Google Home app (not the Nest app)
Here are the full instructions...
https://support.google.com/googlenest/answer/14159897?hl=en
