09-21-2023 11:24 AM
I have a battery doorbell but struggle with not having an in-house audible chime. I also don't seem to be able to get either an audible or vibration phone notification when the battery doorbell is activated. Is it possible to convert the doorbell to a wired set up to connect it to an existing electronic doorbell?
09-21-2023 11:44 AM
Yes, you can connect the battery doorbell to existing doorbell wires. You can see the installation instructions here:
https://support.google.com/googlenest/answer/10732535
You'll want to make sure your doorbell's transformer meets Google Nest requirements:
https://support.google.com/googlenest/answer/9247132
Note that many customers have reported in this forum they needed to upgrade to a 16V 30VA transformer for their Google Nest doorbell.
Here are wiring diagrams for the 2nd gen doorbells:
https://support.google.com/googlenest/answer/12153643
If you have a Nest Mini or Nest Hub, you could use "Visitor announcements" either instead of or in addition to an indoor doorbell chime (enabled with "Indoor chime" option):
09-21-2023 11:44 AM
09-21-2023 12:25 PM
Thanks so much for your quick and super helpful response!
09-24-2023 01:09 PM
@TLP7, thanks for reaching out to us. I hope you've already gotten the answer you are looking for. Please let us know if you still have questions or concerns, as we'll be willing to assist you more.
I appreciate your help, @MplsCustomer.
