02-19-2023 10:50 AM
I changed our wifi to Google Nest with one primary and two other points. Our Nest doorbell (battery) was previously connected to our old wifi router with no issues but now it won't reconnect to the new Google Nest (it is closest to primary point). I followed the online directions to reconnect: I removed the device from Google Home, physically removed the doorbell, brought it indoors, did a factory reset and followed the steps to reinstall and reconnect. The process goes to " Connecting To Joining Device" but then I get "Something Went Wrong". I've tried with our existing Home, added a new Home and tried it as suggested in another post, went back to our original wifi router, but nothing works. Now, when I connect the doorbell to the USB charger, it chimes, light turns white, but does not pulse blue (stays constant white). Any help would be appreciated! Thanks.
02-23-2023 02:54 PM
Hello AldoZ,
Thanks for reaching out here in the Community and for sharing your issue with us. You need to make sure that you reset it properly to the factory default. Also, it should have a pulsing blue light indicating that it's ready to set up.
Give these steps a try:
2. Press and hold the button:
3. Release the button. Your Nest Camera will restore to its factory settings.
4. After the factory reset, your Nest Camera will appear as “Offline” in the app until you remove it.
5. To remove it from the app, open the app, tap on the device, then tap Settings> Remove device> Confirm.
Hit this link for more information.
02-26-2023 10:18 PM
Checking in — did you get a chance to try the suggested steps shared above by Emerson? If so, how did it go? Let us know if you need more help.
I appreciate the help, Emerson.
02-28-2023 04:26 PM
Hello there,
I appreciate the help, everyone.
Archie
