Chime on Mini
Lazerdyn
How do I make my Google mini chime with my Nest Battery doorbell?
It tells me "Electronic Chimes won't work with your doorbell when it is using battery power."
@Lazerdyn
The "Indoor chime" option for your doorbell is disabled if your battery doorbell is not wired, because there is no way to trigger an indoor doorbell chime without doorbell wires.
The "Visitor announcements" option is used to send visitor announcements to Nest Minis, Nest Hubs, and Nest speakers: https://support.google.com/googlenest/answer/7672451?hl=en
janthadeus
Checking in — were you able to follow the steps in the article shared by MplsCustomer? If so, how did it go? Let me know if you need more help.
I appreciate the help here, MplsCustomer.
janthadeus
Hey Lazerdyn,
janthadeus
Just checking in to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
