03-18-2023 07:51 AM
Bought a nest mini as a chime for my nest battery doorbell and it does not connect.
03-18-2023 08:06 AM - edited 03-18-2023 09:11 AM
Do you mean you were unable to install your Nest Mini in the Google Home app? If so, what happened when you tried?
03-18-2023 10:39 AM
It does connect the the app but it does not to the doorbell, in settings the option is grey out.
03-18-2023 11:50 AM
I'm confused. What option is greyed out? "Visitor announcements" is the option you use to send announcements to Nest Minis and Nest Hubs:
03-21-2023 06:23 AM
No, that option is good, I'm referring to the Ring indoor chime option, I see a message on top that says electronic chimes wont work with your doorbell when it's using battery power., does that mean I cannot use the Nest Mini as a chime?
03-21-2023 07:22 AM
The message on the screen seems to be worded poorly and is causing a lot of confusion.
The "Indoor chime" option is grayed out and disabled if the battery doorbell is running on battery power and is NOT wired to an indoor doorbell chime. This makes sense because if the doorbell is NOT wired, it cannot ring a wired indoor chime.
The "Visitor announcements" option should work and should NOT be grayed out if the battery doorbell is running on battery power and is not wired to an indoor doorbell chime. This also makes sense because the doorbell communicates with Nest speakers via Wi-Fi and should not depend on the doorbell being wired. If this option is NOT working, as others have also reported, Google Nest has a defect. In fact, in some cases, Google Nest has been selling a battery-powered doorbell together with a Nest Mini.
(By the way, I'm using the U.S. English wording of the "Indoor chime" and "Visitor announcements" options. Google Nest is using different wording of these options in other languages, which adds to the confusion.)
03-22-2023 10:40 AM - edited 03-22-2023 10:41 AM
Hello everyone,
@Melkor, thanks for reaching out here in the Community. How's it going with your Nest Doorbell? Were you able to link it to your Nest Mini?
Give these steps a try:
Newer Nest Doorbell models and other compatible doorbells
1. Open the Home app .
2. Touch and hold your device's tile.
3. In the top right, tap Settings and then your Nest Doorbell.
4. Turn Visitor announcements on or off.
Nest doorbell (wired, 1st gen)
To turn visitor announcements on:
1. Open the Nest app.
3. Tap Settings and then Visitor announcements. This will take you to the Google Home app.
4. When asked, follow the onscreen prompts in the Google Home app to complete setup.
To turn visitor announcements off, turn off your display notifications. You can also use Do Not Disturb to temporarily turn off visitor announcements for your Google speaker or display.
Hit this link for more information.
03-25-2023 03:33 PM
Hi Melkor,
I'm dropping by to ensure that everything is covered here. How's it going with your Nest Doorbell? We would appreciate it if you could share the information I’m asking above. Also, were you able to perform the steps I’m suggesting? We'd be glad to hear from you.
03-26-2023 03:39 PM
Dan
